I have a voltage regulator that is about 10 feet long. I have to run 4-400mcm conductors from one end to the other where they will terminate on the far end of the voltage regulator cabinet. It is completely sealed when access panels are installed. My question is it code legal to use the voltage regulator cabinet as a raceway or should I run conduit from the surge suppressor cabinet to the end of the voltage regulator terminates. Is the voltage regulator a utilization equipment and can it be used as a raceway. There is plenty of room in the v. reg. and I would like to use the space. There is no chance of corrosion or mechanical damage. I am running the conductors from surge suppressor cabinet to voltage regulator to bypass switch (which is done with 6" nipples and then a main disconnect panel. I would like to come into my voltage regulator from the end nearest the surge suppressor instead of the end close to the bypass switch. But can I use about 10 feet of cabinet as a raceway. Thanks for any help.
