I use a tool called "BendAll" from RackATiers. I cost about ~$30 if I recall correctly.
It's basically a chunk of aluminum about 1" by 5" by 5/16" and it has a 1/2" square hole in the middle and two 1/2" pins about 1 1/4" long sticking out at each end.
Actually I invented this device and then saw it advertised in one of the contractor magazines. So I got one. You need a 1/2" drive ratchet and also an extention bar.
~Peter
they actually work pretty good... i have one. it'll bend 4/0 nicely. and doesn't
beat up the insulation all that much.
for large stuff, hopefully you left it long enough that you can overwrap it, and
then unbend it to make a nice tight ninety.
there are hydraulic wire benders, if you do a lot of large stuff, they are nice
to have.
i've made my own wire hickeys... take a rigid coupling, say 1" or 1 1/4", slit
about a third of it away, smooth the cuts so they don't chew up the
insulation, and weld on a 1' handle of 1/2" rigid to the coupling at an angle,
so you can reverse it like an open end wrench... the threads in the coupling
keep if from slipping.
