What do you think about purple & blue 3/c Romex??
What do you think about purple & blue 3/c Romex?? Would you use it?
  • Yes
    Votes: 9 64.3%
  • No
    Votes: 0 0.0%
  • Don't Care
    Votes: 5 35.7%
  • Total voters
    14
  • Poll closed .
One of my local supply houses has had 14/3 NM that has a red stripe down the jacket. I believe it's Encore brand. Their MC cable has a yellow tape band every 4 feet with "12-2" marked on the band and 10-ga is an orange band. I think this is a better way.
That part is either way for me.
Footage markers would be amazing. Even if it was only every 2 or 5 feet. I'd take anything
Is not so useful if inner end of the reel isn't accessible though. I have a reel of URD right now that was cut to length at supply house but was to have multiple cuts off it in the field. Now I am down to the last run and will have to unreel it to find out if there is enough left for this last run as I can't get to the inner end to see what the marking is there. I ordered the cut not knowing much of the exact path it would need to take when buried. Had two other reels for same project that ended up having enough on them hopefully this one does as well.
Is not so useful if inner end of the reel isn't accessible though. I have a reel of URD ri....... ..
I may not visualize what you saying.
Why do you need access to the end? If the cable is marked with the footage you will know how much is left.
Not if they weren't told what the starting number was when the cable was spooled.
I see, "....when the cable is spooled". Yes that makes sense.
But I was referring to a pre-cut rolls or spools.
I know it is not exact, but at least an idea of what is left.
I figured the issue was not knowing how many feet you have remaining.
It is.
I think the concern is: Let's say he ordered 235' for three runs of, say, 100', 75', and 50' with a 10' extra.
After making the first two pulls, he wants to be sure the 10' was enough extra before pulling it in.
I do plenty of low-voltage work. Those cables all come with footage markings.
It is.
Yes, exactly. That's also what I was referring to. 🤔
This is my PL.
I have several old roles of white 12/2 NB-B sitting on the shelf. I plan to use it on my new house next spring. Wondering how badly this will spin the inspector, LOL.
I dont see a problem with the color of the Sheath, be nice if the Conductors were a Different TONE of Black and White then we could use it Help separate HR's and such. Regardless could still be used to Identify.
It may be useful when trying to identify a cable bundle up in a group.
