What's the purpose of the ground wire being wrapped around this metalic core thing? It's on a fan for a bathroom.
Take it off and see if any AFCI or GFCI trips in the house while cycling the fan off/on.
Is there an electronic speed control? It might leak enough RF noise into the EGC to cause trouble (or fail an FCC approval). The ferrite core will suppress that noise; that's the main reason you see them anywhere.
IDK. in the earlier days of AFCIs we tried about everything to keep them from nuisance tripping and if I had had a couple I would have tried it.Already left from the house. Does it affect the AFCI or GFCI breakers? Like the first guy said it's weird that it's on the ground wire. How would that effect anything unless it plays some part in ground faults
. Never say never.They are to suppress high frequency noise,
weather it is incoming or out going we cannot say
but it works any way
WILL NOT EFFECT GFCI.
its called a ferrite core.
I was thinking it was to suppress any incoming noise... you're probably right in thinking it's to comply with FCC or international communications regulation(s).
How much impedance does this add to the fault current path?
Just an fyi it's called a ferrite bead
