Hi,
I often hear the term dry contacts with relays. I have heard several explanations that are conflicting can anyone explain this word to me.
MJC1060:?
According to IEEE 100 (Dictionary)
"dry contact is a contact through which no direct current flows."
That's what would take to mean to.I always understood it to mean not a source of power, just a switch.
What about alternating current? :lol:
OK, so if no current flows, how does a contact DO anything?
A very good point, and one which is directly relevant to the OP's use case in which there will be very low voltage and current through the contacts.Dry contact is different than "dry circuit rated". Dry circuit contacts are suitable for current flow approaching zero and are frequently used for switching analog voltage signals into a high input impedance device. They may be, and often are, also dry contacts.
i use them to close a circuit consisting of a coil of wifre inside another coil to change the inductance of the second coil for the signal to a controller for vehicle counts, etc.
But how is that accomplished without current flow?
Does that mean that they are "dry" only until they are installed?I'll make it easy for you all. You go to the supply house and purchase a wall switch. Doesn't matter if it's SPST, 3 way, 4 way. You have just purchased a switch with dry contacts.
The current that flows in the switched coil is entirely current induced in it by a sensing current applied to the concentric outer loop. Basically current is driven through the outer loop to measure its inductance and Q, and short circuiting the test coil inside the loop changes those parameters.
Just because no external voltage is applied to the inner coil and indeed no external connections are made to it, does not mean that there is no current. A short circuited secondary in an isolation transformer is an example of this.
