FaradayFF
- California
Greetings,
In a scenario where a fuse is undersized and the short circuit through the fuse is higher than what the fuse is rated for, the fuse will still blow, agreed? If that is the case, why is it still important to have the rating on the fuse higher than the max. available short circuit current(other than NEC requirement, of course). I can see that for a thermal magnetic circuit breaker, if the short circuit duty is higher than the max. interrupting rating of the breaker, the breaker may fail to open and quench the arc. For a fuse, the current interrupting mechanism is different..
Thoughts?
Brother Sparky.
Thoughts?
Brother Sparky.
