Fulthrotl
~Autocorrect is My Worst Enema.~
- E
Yes this is for stage equipment he wants me to supply the camlocks on a panel from the breaker panel. so do I run conduit to a j box and mount these camlocks to the front of it? he wants 200Amps. thanks for the help so far.
2/0 is normally what is used for 200 amp tails on trade shows.
not judging, just reporting facts. they'll use 3 4/0's in parallel for a megawatt.
true story. they used fans. lots of 'em. they core soaked a half megawatt
dry type transformer, and it was damaged enough to require replacement...
(CES, las vegas)
back to the dimmer panel feed.....
use 4/0 welder cable for the whips. neutral and ground are reversed,
unless it's west coast lighting... they do things dif'rent.....
pipe to 12x12x8 box, unpunched box, pull your own holes, and use
kellums for the tails. any concentric knockouts will be destroyed in
72 hours in a show environment.... use unpunched boxes.
anyway, thats how it's done around these parts.... i did trade shows
for over 2 years straight.... let me restate that.. i did trade shows
continuously for two years... nobody can do them straight.... you go
into the bathrooms in the convention centers in those days, and it was
either a plumbers convention, from the sound of the blowtorches, or
their was some serious drug abuse going on....
