We have used Leviton. Don't recall any callbacks, but they could have just quit using it once it failed. That still equals No callbacks.
The simplest flavor, giving you an SPST master and a battery powered remote (6696-W) is not listed to work with CFLs or LEDs, although the trick of adding a small (~15W) incandescent to the load circuit has been reported to work.
This particular flavor does not require any wiring at the remote(s).
None of the wireless solutions should be confused with the multi-way products that require a communication wire that links all of the switch locations but does not carry load current.
PS: Any models that include dimming are even less likely to work with CFL or LED. I have seen a description that the light comes on in two steps over a couple of seconds, which could damage non-dimmable lamps.
