- Windsor, CO NEC: 2023
- Hospital Master Electrician
That's still the case, 250.53(D)(2).tom baker said:I like to use the water pipe as a GE. But until the 2005 NEC it always required an additional electrode.
With the circuit EGC as per 250.112(M), or with a GEC from the service? Just curious.tom baker said:Even if the well casing is not a GE, I still bond to it.
Do you have the 10' text from the Washington State code handy to post?
Does the outhouse have a panelboard installed on it?amptech said:You wouldn't need a ground rod at an outhouse, would you?
Thanks for the replies thus far, a lot of food for thought has been offered.
