Barbara I
New member
- Anchorage, Alaska
Is a greenhouse fan considered an appliance? Product in question is ES Shutter Fan by J&D Manufacturiing #VES20C, 115V. The motor of the wall mounted fan is UL rated, the manufacturer tells me there is no point in UL rating the fan, it is not an appliance and because the motor is UL rated. Our inspector is saying this is unacceptable and the wall fan is considered an appliance because it is affixed to the wall and as such the entire unit needs to be UL rated.
I found this exception in the state code "an assembled device that has an electric circuit that operates at 110 volts AC or higher, except for mechanical attachments, including pumps heads, pulleys and fan blades, that are used in the application of the device"
Is there a similar exception in the National Code?
