gilamor said:I am need to connect an air-condition rated 240 50 Amp 3 wires (2 hot and ground)
Can someone tell me if I can use 8 AWG THHN
I am running 3 single conductors THHN in ? flex (2*8 awg and ground 10 awg).
OK, introducing example 3A of NEC-2005:
You have to make TWO different calculations in order to get the answer. One is the ampacity due to the terminals at which is connected the cable. The other one is due to the installation conditions... and No, I'm not going to say nothing about voltage drop
Ampacity due to the terminals: Let's first assume that the device's MLA is 50A (covering 440.32 or 440.33). The OCPD should be less or equal than 100A (1.75 x 50 = 87.5 A, 440.22). Let's choose a 70A OCPD (OK, it all depends on the nameplate). A 70A OCPD could be listed as 60/75?C, so we can either columns in the tables...but, we don't have the temperature rating of the air-conditioner. So, we have to choose the conductor from the 60?C column: Is the air-conditioner going to be used more than 3 hours? then, we calculate 1.25x50A = 62.5A.
From Table 310.16, it should be 4 AWG (70A)
If the air-conditioner is going to be taken as a non-continuos load, then we choose a 6 AWG (55A), enough to carry 50A.
Ampacity due to installation conditions:
In this part of the calc?s is where we ask about how are the wires and conduit going to be installed: 3 wires in conduit, and let's assume that we're going to be between 31-35?C (87-95?F). So, we take into account the derating factors: # conductors <4 so the derating factor due to the number of wires is 1.00 (no derating) and for a THHN wire (90?C), the temperature derating factor is 0.96, from table 310.16. This ampacity shall be: 50A/(1.00 x 0.96) = 52.08A. Selecting from the 90?C column, we see that 8 AWG, can take this (55A)
Bad news, amigo m?o: we have to choose the largest one between 4 AWG and 8 AWG (or 6 AWG and 8 AWG). And there is another calc for the neutral...
This is just an application of this example 3A as a guide, The next link guides to a clearer explanation. Hope it will be useful: :wink:
http://www.iaei.org/subscriber/magazine/03_d/magazine_03d_hartwell.htm
Saludos
