sliderule
- Langley, BC
Here in Canada, a delta primary with 120/208 volt wye secondary is standard in commercial applications, then up from there, 347/600 volt wye secondaries (both with grounded neutrals. I thought in the US, a delta primary with 120/208 wye secondary is common and then 277/480 volts.
Some told me today "A DELTA transformer with mid-phase neutral tap is the norm in the USA. Down here four wire high voltage 3-phase transformers are the norm. Wye connected transformers." Not exactly sure what he is saying. Is he saying a wye primary with a mid-tap delta secondary is the norm for the US?
Thanks
Thanks
