Meterman Eng
- WA
Got It
Got It
Ah, thanks. You got me on the 42.
Got It
1VIt's from the same source. It's a box with a battery in it. And you're supposed to plug something with an equal amount of holes into the spikes. So what would the voltage be? How would you determine it?
I knew I should have brought my towel today. ...
Is there only one battery? If so, the voltage cannot be anything other than what that battery supplies.I think the source is the same, but I am unable to open the box to see what's inside. But I notice the voltage is the same for each spike. So that must be the voltage?
The same source? What is the reference point? Are these spikes stuck in an orange? An insulator? Nothing or someones forehead?
I vote forehead. More people need Electroshock Therapy.
By the way, you need silver spikes for werewolves. Voltage optional.
On a serious note, 20 1.5V batteries (spikes) would produce anywhere from 1.5 to 30V, depending on connection... probably not 30V in series due to loss, but close enough.
If I put 10,000 9V batteries on my body, will I be electrocuted, be a modern work of art, or both?
Depends on the battery.I think the source is the same, but I am unable to open the box to see what's inside. But I notice the voltage is the same for each spike. So that must be the voltage?
What's the difference between an orange?Is there only one battery? If so, the voltage cannot be anything other than what that battery supplies.
"Voltage" always must relate to a DIFFERENCE in potential from two points.
What's the difference between an orange?![]()
If you say "orange" slow enough, it sounds like "gullible"...What's the difference between an orange?![]()
Crushed most likely.
OK. "The power is on.":lol:What about total resistance? What would be the most effective way to measure it? Say the power is on
Thanks for your responses by the way, everyone.
And you got me! So you turn the power off before you measure it. But then what? Would you put the leads on two different spikes/plugs? How would you know what the total resistance is for sure? What's the method?
