ces
- Northern California, USA
This aluminum cable is one of many we will be insulation-testing next week in a 5 story office building built in 1969. If any cables fail we will have to replace the cable, we are already replacing the main switchboard, all panelboards and 480-120/208V transformers.
The building has 3 dual cable-risers (480 and 208V) using these ancient conductors with numerous splices/kerneys on each floor. When we test I expect to leave all conductors in place unless we have to disconnect -for example the transformer secondaries which have no disconnects.
I should add that the intent is for the building to last another 25 years, not 50, and our budget for the replacement of the electrical distribution system is already committed to. Whether or not these cables hold up is a BIG DEAL.
My question is - what is this cable? The AL is very light weight the conductors flex/bounce a lot more than modern AL conductors.
My first concern is whether it will pass or fail insulation testing. I've been reading about this all day on this Great Forum and so far conclude that I should test the 480V at 500V and the 208V at 250V and not double these voltages which could reduce readings, and take 30sec and 60sec readings. There have been a number of faults in transformer and distribution boards leaving carbon dust in this equipment. Should we attempt to clean this (vacuum, compressed air etc?) if we get low readings? I assume the carbon could be a contaminant effecting readings.
My next concern is that if we pull these conductors out of switchboards & panelboards and replace the switchboards and panels by the time we re-terminate will this insulation be compromised, or with proper care will we be able to reterminate? Perhaps we tape or cables before touching them?
I should add I don't pull wires for a living I just size them on paper ... but I do have some responsibility for making sure we get this building tested in a one-day shutdown, for establishing test parameters and interpreting the test results, and for designing a new distribution system to cost effectively reuse existing wiring.
Any and all comments appreciated -Gary
