what is this fitting?
I have seen plumbers use something very similar with a peice of rubber inside to temporarily stop leaks
Sent from my SM-N920P using Tapatalk
There is a similar electrical product called a "split coupling". Here is a CrouseHinds sample.
That may be one of a different manufacturer.
I installed what seemed like a thousand of those in a plastic resin conveying system that I built from scratch for one of our plants. Started commissioning the system on a Monday and got told on Wednesday that the entire system was going to be moved to another plant.
That fitting probably has a stainless steel sleeve inside a rubber sleeve covered by the visible steel. Definitely not code compliant or listed but a hell of a solid connection.
And probably does not establish a solid electrical connection if the raceway is expected to serve as an EGC.
Ahhh, there it is! So what is that for? For when you pull the wire in but then realize you forgot a coupling? ;)
Maybe repairing EMT that has been smacked with a forklift and cracked/split the original fitting so that it wont tighten up properly again. Lot quicker than tearing apart the entire run to do it correctly.
What is shown in the OP is a "low pressure repair clamp", (not listed for electrical AFAIK) not a split conduit coupling as shown by Gus and linked to by Dennis.
Roger
