L Leitmotif Member Dec 8, 2005 #2 Re: what is Also called a pressure switch. Air pushes diaphragm connected mechanically to switch. At set pressure switch is moved (shut opened etc) COme in all flavors air vacuum, water hydraulic.
jwelectric Senior Member Location North Carolina Dec 8, 2005 #3 Re: what is Originally posted by Leitmotif: Also called a pressure switch. Air pushes diaphragm connected mechanically to switch. At set pressure switch is moved (shut opened etc) COme in all flavors air vacuum, water hydraulic. Click to expand... Pneumatic switches will not be water nor hydraulic.
charlie b Moderator Staff member Location Lockport, IL Occupation Retired Electrical Engineer Dec 8, 2005 #4 Re: what is I think he was talking more generically about pressure switches. They do come in those other flavors.
