carryyourbooks
I have been tasked with installing 2 machines. Each of these machines will have (2) motors: (1) rated at 200hp @ 480v/3ph and (1) rated at 20hp @ 480v/3ph. For one of the machines, I have an availble 800a, 480v panelboard availble. For the other machine, I will need to build a new service. With the new service, I want to leave room to add other circuits if needed.
So, first, is the 800a panelboard adequate? IMO, I would prefer to put both machines on the same breaker, bring my feeders to the outside where the machine will be located and install (2) fusible disonnects for each machine.
For the second, what size service would you recommend? Should an 800a service be adequate?
TIA.
TIA.
