What the Heck is the Deal with ASBESTOS
jes25
Midwest
Hello all, been a while since I've been on the forum. Glad to be back with all the best electricians in the country!
Anyhow, I'm wiring an old house and I start worrying about asbestos again, I generally wear an asbestos-approved mask when working on old stuff, but I've always kind of known that wasn't enough. So today I decide I'm going to start doing some research. My first stop is an asbestos "handbook" on Amazon. Basically this guy goes on about how asbestos will kill you and that it pretty much was put in everything including electrical insulation and wall coverings all the way up into the 1980's. He then details all the lawsuits and jail time people have received for unknowingly disturbing asbestos and how its illegal to even take a sample to the lab unless you are certified by the EPA.
Next, I start reading my states laws and OSHA / EPA regulations. I learned their are 4 classes of asbestos work - the lowest level being Class IV which includes something as simple as a janitor buffing the floor. After trying to read the law, I surmised that myself, and pretty much every tradesperson, should be trained in Class III (minor cutting, drilling etc.).
So I start looking for classes. Not a single one offered in my state that I could find. Now how the heck can this be regulation / law and I can't a find a single class offered? Seriously, I know everyone just ignores all this stuff, but I have spent hours trying to figure out where to even start to do it the "right way"
So I'm wondering your thoughts. Do you or your employer have a set of rules / procedures regarding asbestos? What are they? If not, are you concerned about the health effects or possible lawsuits? Any recommendations on how to start this conversation with my own employer? I don't want to be a PITA, but I also don't want to die early, get sued, or worst-of-all contaminate a customer's house or children. I'm also interested if anyone has any insight on the real level of risk here. Is asbestos a carcinogen like second-hand smoke or is it much worse?
Sorry for the long post! And thanks for the comments in advance.
My attitude toward it is that I've been around it for so long now that it will probably kill me at some point. :p The backstory is that I have done old work for most of my career on old buildings. Here in the northeast we have the oldest housing stock in the country and it's all filled with asbestos to some degree. There is really no way to escape from it. So I don't worry about it. :slaphead:
the hysteria around it is a bit nuts. it's not plutonium.
however, getting it in your lungs is bad. the stuff is like microscopic
foxtails. it gets lodged in tissue in the lungs, and festers.
it's accumulative, as there is not way to remove it. some of it will be
coughed up, sneezed up, etc. but once it's there, it's there.
it varies from state to state, but working with it is a special licensure.
disturbing it is a no no. and yes, it's everywhere.
scattergood generating station, right behind LAX is a good example.
6 stories tall, and 300 yards long. the entire building was built of corrogated
asbestos sheeting, 1/4" thick. if you need a hole cut, you mark it out, and
an approved contractor cuts it for you. a 2' hole, a 1/4" hole. doesn't matter.
knowingly handling it without certification will get hellacious fines if caught.
Geez.. Asbestos... Simple: If you know you have it or suspect you have it then wear masks and get misters into place, along with heavy air filter stuff... but you do the same basics for heavy pest infestations as well...
As you pull items mist the area and bag it immediately, dont let it sit around...
Get it into the skip quick as well...
Rinse area down and vacuum well...
OR: Spray paint or spray foam the whole area to encapsulate it...
If it is wrapping pipes and looks ok, and you do not need to mess with it, simply spray paint it to keep it better...
A few of us worked at a veteran's hospital for two years running pipe above the drop ceilings. The area was full of asbestos. We received training on how to protect ourselves and other's around us. Here's is what we had to do:
Setup a negative pressure containment where we were working. Basically it looked like a phone booth which sealed to the ceiling and had a HEPA vacuum sucking all the air out and filtering it. The ceiling tile could not be removed until the containment was in place and running.
While we were inside the containment we wore a bunny suit (aka disposable coveralls) with a hood and gloves and a respirator. We sealed the sleeves to the gloves with duct tape. We pulled the hood tight around our faces and sealed the opening below our chins with duct tape. We sealed the leg cuffs to our boots as well. Basically you are trying to keep all the asbestos out of the suit. You don't want to track it home on your clothes where you will expose your family.
A specialized asbestos remediation contractor was there to remove asbestos when needed and properly dispose of it.
Thanks all for the replies. After reading them and thinking a bit more, I think what's bothering me is how to handle a small project - say adding some lights- in an older building when the owners hasn't tested for asbestos. What do I look for? What can I do safely and what needs to be tested?
I've reached out to local environmental firm regarding training. If anyone is interested, I'll report back when I learn more.
i've got a firm that will do tests for $25 each and give a yes/no over the phone.
it was a good way to find out without officially knowing, and without having a
structure tagged officially.
honestly, you can't officially do anything without test results. acoustic popcorn
ceilings are notorious for them putting asbestos in the material, as it made it
stick better, and you got better milage on the product.
fireproofing, or monocote was also notorious for the same reason. people would
have a 100 lb bag of asbestos, and throw a shovelful in the monokote pump
every so often.
a shop vac that is asbestos worthy is the festool vacs. they are NOT certified,
but they could be. festool doesn't want the liability. they ARE lead paint certified,
so you can do RRP with them.
here's the thing. if you get it airborne, it gets everywhere, and ends up in airborne
dust, and everyone breathes it. you'll notice i have not made one suggestion as to
methods of handling it. really the last thing you want to do is do asbestos remediation
without a certificate.
when i was working for LADWP, they asked if i wanted the asbestos training and license.
it would increase my marketability as an exempt employee, and virtually guarantee
permanent employment. none of the civil servants would certify.
all people with the cert did was work as an electrical mechanic in abatement areas.
who wants to spend the rest of their professional life in a bunny suit with purple cartridges?
I use to breathe Asbestos in the raw form. We had barrels of it. We stored it in our work area without lids on it. When we mixed it you could see the fibers floating in the air, We had several different kinds. The real tiny powdery kind, to the one inch fibers big enough to spray in attics. When the barrel got low, I would grab another couple bags and bust them to fill up the barrel again.
We never wore a mask.
It's been reported that some times it might take 20 to 30 years to feel the damage in your lungs. I breathed it in the raw form like this for about 5 years starting in 1976.
We were told it would cause cancer. But... that's when Saccharine reportedly was causing cancer in Lab Rats, but... they had to eat equivalent to a 55 gallon drum of it.
People were not taking Asbestos seriously because of the Saccharine study.
Finally in Seattle, Osha came into the shop with a poster of an Asbestos fibers. The best way to describe it, is that the fibers have long barbs on it like a fish hook. Like Fullthrotl said once breathed in, a lot of it does not come out.
Several years later. I was sent to another shop in Houston. They were still using it. I described to them the fish barb theory. They got rid of it immediately
However , the good news, like me, is that most people never feel any affects of it.
But … It has been reported that some people can barely come into contact with it. Then get Asbestosis and die.
Their were about 15 of us that worked in the shop at the time. Several have died un-related to Asbestosis. None of us have had any affects from it. None of us smoked.
None of us have got cancer from it ( Asbestosis) I'm not cheering that I've not had it. Its still possible. I get a lung x-ray every now and again.
In Indiana, you have to be state certified to remove Asbestos, But their is no state license to do electrical work.
well, we've all had some variant of this... for me, i was 21
and used to degrease capacitors impregnated with poly-b,
one of the most notorious PCB's.
what did i degrease with barehanded? vapor degrease
using 1,1,1 trichlor at 150 degrees F.
two years of that. i also tested those caps with 36KVDC
barehanded. technique was everything. there was 1 amp
available at that voltage.
i used to do my dirt bike chains on my lunch break....
degrease in the tank, and drop them in a bread pan full
of poly-b, and a shot glass full of graphite. pull a vacuum
on it.
then put it on the bike, and spew it all over the desert.
it's all coming back to me now....
Haha, everything in moderation!
I still cast lead, have crawled over, under, through, soaked stuff in gas bare hands, eat fat, drink, stopped smoking years ago, speed a bit, California stops, salt, butter, ice cream, who knows what we have been exposed to. Take some of the new drugs your parts will fall off, when your sleepwalking naked on your way to gamble and have unprotected sex.
As with most carcinogens, there is not a clear understanding on what truly "triggers" the cancer, so risk is hard to really estimate. There is one fact, though, each fiber you breathe in could theoretically cause it. Really bad way to die too.
I was a certified asbestos Building Inspector, Contractor/Supervisor, and Project Designer. You are right, EPA requires anyone even taking a sample be certified inspector - I think it's ridiculous, anyone can have any other carcinogen tested without any cert.
You are looking for "O&M Training" (Operations and Maintenance). About $300/person, 16-hrs. I'm sure regionally that changes.
1980 is the rule of thumb year cutoff for most residential materials - but that doesn't mean a contractor didn't have a warehouse full of chrysotile asbestos that they kept using. Despite popular belief, many uses were never "banned." Roofing/flashing mastic still has it on a fair occasion - we would find it on brand-new buildings in ~2008. https://www.epa.gov/asbestos/us-federal-bans-asbestos
Here is a list of "suspect" materials: https://www.des.nh.gov/organization/divisions/air/cb/ceps/ams/documents/materials.pdf While I can usually make an accurate guess on insulation and popcorn ceilings, there is no way to be sure without lab testing. Sheetrock is unpredictable.
The building owner has the responsibility to do testing before anything is disturbed - this is often ignored.
With the assumption that you will mostly be disturbing sheetrock or plaster in J-box sizes:
To protect yourself -
  • Don't use power tools to cut into suspect material, only hand tools.
  • Use shaving cream when drilling - put a big blob of Barbasol on the wall and drill through the blob. Can try to use it when sawing, but it gets messy.
  • Don't use a vacuum without a real HEPA filter - a non-HEPA makes it worse by blowing the fibers into the air. If your vac didn't cost hundreds, it probably isn't true HEPA. The fibers take hours to settle.
  • Use wet methods (wet sponge/towel/etc.) to clean up; don't dry sweep.
  • If you are cutting in recessed lights, get the plastic can light "dust bowl" and utilize the shaving cream on the drywall and in the bowl to capture the dust - easier dust cleanup even if not asbestos.
  • Half-face respirator with P100 (pink) filters if it gets dusty (use the other controls to prevent dust). Your employer needs to have a Respiratory Protection Program for these though or they could get cited if OSHA sees the respirator in use.
I am glad you also see the risk to the occupants after you have done your work -
I can't count the number of times that some poor homeowner called me as a consultant to tell me that they had their popcorn ceilings or VCT removed without checking for asbestos first. More often than not, they had kids. Fortunately, they all lucked out and when we took samples from some dark corner that wasn't scraped, it was clean (post 1975 homes in AZ).
on it.
It's been nice knowing you. :bye:
Call the nearest OSHA office https://www.osha.gov/html/RAmap.html They won't take down your name or anything, and they truly want to help. Ask to speak with the Compliance Assistance Specialist (if there isn't one, ask to speak with the area director or assistant area director). Those folks may be able to point you toward the training you need. To get your feet wet, see if you can get into a 10- or 30-hour class in OSHA Outreach Training for the Construction Industry. That will give you an overview of asbestos, lead, electrical safety and many other topics. Ask the OSHA folks for the number of the nearest OSHA Training Institute Education Center. They might have a more specific course, maybe online.
If you have employees and workers' compensation insurance, call your carrier's loss control rep. It sounds like you're not doing anything unusual, like asbestos abatement, just old work without disturbing a lot of presumed asbestos-containing materials, so they're well aware of the hazards you face and would rather help you than pay a claim later.
If you're working for a large construction manager or GC, they have a safety person who may (or may not) be well informed, and probably have a safety program that will give you some guidance.
If yours is a union shop, the IBEW might be able to hook you up.
See if there's a local industry association like the Associated General Contractors or Associated Builders and Contractors. They'll have safety committees with members who can help.
Good luck.
For anyone who is interested in this thread or topic, I have an update. First off, I think I have an answer to my original question about what the heck the deal is with asbestos. Without getting political, I think the issue is that everyone is so afraid of getting sued, and industry is so concerned with keeping the status-quo, we haven't been able to pass any sensible regulation on how to safely & practically handle asbestos. We are the only developed country without a current asbestos ban. Feel free to read up on it, you just have to wade through piles and piles of lawyer ads disguised as being real information. From what I've gathered the OSHA requirements are so impractical for a electrician adding an outlet, and everyone is so scared of being sued they would rather just ignore it then take do anything at all.
All that to say, if you'd like to learn how to be safer around this stuff, I found some great publications for tradesman on asbestos from the UK and Australia. Here is an example:
https://inspectapedia.com/hazmat/Asbestos-home-renovators-trades-guide.pdf
Why can't we offer a practical guide like this?
And for perspective, I'm coming from the standpoint of an electrician making his living cutting in plugs and recessed light in older homes. And I will be taking the OSHA course next month.......
I know this post is a month old, but here are my thoughts:
I live in Virginia. A few years ago I was renovating a house that was suspected to have asbestos siding and possibly asbestos pipe insulation. In Virginia, you have to be licensed by the state to Abate certain types of asbestos. The siding was a non-issue, as long as you do not grind or drill it, you can pretty much remove it and throw it in a trash bag in a standard landfill. pipe insulation is far more strict, I believe you can remove 10 linear feet before you need a license and special abatement procedures.
As far as interior surfaces, breathing sheetrock dust, insulation fibers, and being subject possibly to black mold or animal droppings during the course of normal work are all far greater dangers to me than asbestos. If you had to tent off a house, set up negative pressure HEPA filtration, and suit up like you're cleaning up a EPA Superfund Site every time you cut a 4in circle out of a ceiling for a can light, they would probably cost about $5,000 per can...
If you're just worried about your own health, a respirator and Tyvek suit are good starts. A red 3M filter in the homeowners furnace and their air conditioning turned on along with a nice high flow HEPA filter in the work area would go farther. Spraying down the work surface with water is still yet another cheap option. If you are legally bound to do certain things when dealing with confirmed asbestos, it is best that you follow all guidelines/laws for your state.
It is obvious you have more than passing knowledge of asbestos. So do I, having worked on naval submarines in the early 80's when they were actually making the final efforts to encase and/or eliminate asbestos from ships and boats.
That said, the "hysteria" thing is a hard one. My boss died two years ago from Mesothelioma. Got it from working in the auto industry in Michigan, Indiana. My brother-in-law died from the same thing, likely secondary contact with his father who worked in a shipyard and had OCPD from it and/or from smoking.
bottom line is it is hysteria to worry about most things, until it isn't. Basically until it is too late.
