Agreed.. but conductivity aside when the saltwater gets into the wire, it's very corrosive to the copper wires.I would be concerned about salt infusion. When salt dries it isn't conductive but when it gets wet it is.
Replace esp if covered by insurance.
If they have removed wall covering because it too was submerged then you should be able to visually see said pinched wire if it exists?How many houses have been wired by qualified persons who were careful in securing and handling the romex?
Pinched wire + water/contamination = fire
Also put in nail plates as needed, in case a mad carpenter with a nail gun gets loose in the yard.Just use cable ties and no staples lol
If you choose not to replace, remember salt is also potentially corrosive. If you do not have the wire to spare to cut back, do your best to make sure the ends of the wires are clean and smooth surfaced.I would be concerned about salt infusion. When salt dries it isn't conductive but when it gets wet it is.
