- Massachusetts
Re: What Voltage?
I will give you the code rules and you can make up your own mind as to what you want to do.
Remember if you choose to ignore the code and something happens you will be in a bad position to defend yourself. Everyone wants electric work on the cheap, you as the electrician have to explain the rules to them.
ARTICLE 702 Optional Standby Systems
I. General
702.1 Scope.
The provisions of this article apply to the installation and operation of optional standby systems.
The systems covered by this article consist of those that are permanently installed in their entirety, including prime movers, and those that are arranged for a connection to a premises wiring system from a portable alternate power supply.
Forget about an ATS go with MTS (manual transfer switch) they are much cheaper.702.6 Transfer Equipment.
Transfer equipment shall be suitable for the intended use and designed and installed so as to prevent the inadvertent interconnection of normal and alternate sources of supply in any operation of the transfer equipment. Transfer equipment and electric power production systems installed to permit operation in parallel with the normal source shall meet the requirements of Article 705.
Transfer equipment, located on the load side of branch circuit protection, shall be permitted to contain supplementary overcurrent protection having an interrupting rating sufficient for the available fault current that the generator can deliver. The supplementary overcurrent protection devices shall be part of a listed transfer equipment.
Transfer equipment shall be required for all standby systems subject to the provisions of this article and for which an electric-utility supply is either the normal or standby source.
