ggunn
- Austin, TX, USA
- Consulting Electrical Engineer - Photovoltaic Systems
No, what they are describing is expansion joints in the PVC conduit, and the straps need to hold the pipe loosely enough so that the PVC can slide in the straps as it expands and contracts. Yes, there are tables in the NEC for calculating how many joints are needed and where they need to be placed. Also, you'd need to allow for some movement in the wire when the conduit moves.Thanks for all the responses.
This is concrete-based stucco. There is no foam here.
I read that friction-fit fasteners should be used in this application to allow for expansion/contraction. Is this similar to what you guys are describing?
Aren't there specific code requirements for how this should be done?
But I agree with whoever said that it should have been metal conduit instead of plastic.
