Pierre C Belarge
- Westchester County, New York
A person takes a test measurement with a voltage tester at the panel installed 118 ft from its source. The conductors are 4 AWG, with an actual load of around 16-19 amps. A 240 volt load to a pool pump is the largest load on that panel.
One of the test leads is connected to the grounded conductor/bus (4 AWG), the other test lead is connected to the equipment grounding conductor (8 AWG).
The resultant reading on the tester is 5volts.
What has the person just tested for?
Is this reading acceptable?
