jeff43222
- Minneapolis, Minnesota
I'm in the middle of a kitchen remodel job, and the GC asked me to add a light and a couple of three-way switches at the top and bottom of the stairs just off the kitchen. No problem -- the job is T&M all the way.
Homerun from the panel to the switch (in a new box) at the top of the stairs and running 14-3 from that switch to the switch at the bottom of the stairs was no problem.
Putting in a new switch at the bottom of the stairs is where things get hairy. The wall is opened up, and in that location is an existing single-gang box with two single-pole switches in it (two switches on one yoke). One switch controls the workshop lights, and the other is a total mystery. The box has three runs of old AC going to it (cloth insulation). GC and HO want the new three-way switch in that location and don't want to demo the old stuff.
So the plan was to rip out the old box, put in a new two-gang box, reconnect the old switches, and put in the new three-way switch. But the existing runs of AC have very weird wiring in them. One run contains two hots from the same circuit, but no neutral. Each of these hots was connected to a switch pole. The other two runs each have one of the switched hots, as well as an unswitched white wire that is spliced in the box. I naturally thought it was a neutral, but the workshop lights worked just fine with it disconnected. I have no idea where the second switched hot wire goes, or what either of the white wires is connected to elsewhere.
My concern is that two of the runs of AC have only hot current running through them in one direction, so there is the inductive effect to consider. Then there's the issue of the workshop lights getting their neutral from a mystery source. Finally, there's the mystery run, with a switch that controls it. Complicating matters, the entire basement is finished with wood paneling (1950s style), and the ceiling is also finished with tiles. I already found plenty of buried j-boxes just working on the kitchen, so it wouldn't surprise me at all if the mystery run connects to a buried j-box somewhere.
The GC suggested that I just reconnect the old switches the way they were and forget about them, but I'm not so sure that it's wise to do that.
Anyone care to venture an opinion?
