What Would YOU do?
What Would YOU do?
  • Total voters
    50
busman
Northern Virginia
Master Electrician / Electrical Engineer
The following happened to a good friend of mine. He was called for dimming lights and strange smell. When he gets there, the panel is starting to melt-down. He throws the main breaker, but the short continues. What do you do?
iwire
Massachusetts
Depending on the severity I would call the FD, let them deal with it.
They have great phone numbers for fast action from the POCO and can deal with any progression of the problem.
On the other hand if you try to pull a meter or cut a drop that is under fault conditions you may be successful or it could blow up in your face. My safety rates higher to me then someones property.
480sparky
Iowegia
Burn, baby, burn.
Sorry. But my arse is more important than someone else's property. Besides, they have insurance for these kind of things.
They do have insurance, don't they?
busman
Northern Virginia
I don't want to reveal my friend's choice yet, but my choice was call the FD and clear the building.
busman
Northern Virginia
Actually. He cut the seal and pulled the meter. My first reaction was that if I was in that situation, I'd get the ladder, gloves and sleeves and cut the overhead drop. For some reason, pulling the meter just felt wrong.
A side question might be: what if you were in this situation and the FD wouldn't go in the residence until the power is off and the PoCo isn't there yet. People may be inside. Which would you do?
Mark
byourdesky
vista,ca
Mark
How big a house we talking here?....I guess I would clear the house and do what I could....but I've never been in that situation so it's a tough call
SEO
Michigan
If the panel were melting down you would have probably have time to evacuate everyone before the house became fully engulfed.
fireryan
Minnesota
I am on a fire department and we are equiped with one of those power company meter pullers that are made of plastic. They sometimes have a fit when we do it but we have also waited for 2hrs for them to show up. Its actually a akward situation but when you have someone in a burning house time is of the essence. Was wondering why you felt more comfortable cutting the overhead rather than pulling the meter
iwire
Massachusetts
Both are dangerous, if I had to make a choice I would rather cut the drop from the safety of a bucket truck.
Meters are not designed to open a load and if you have a serous fault on the load side of the meter it may have several hundred amps passing through it. When you pull it you could cause an arc that would result in a flash over.
busman
Northern Virginia
I really don't know. Instinct I guess. Part of the reason for the question. I guess I felt that a quick cut out in the open (from a few feet below the conductors) was preferable to opening the meter can and pulling it. I've seen the plastic meter pullers. They would make me feel a little better about pulling the meter.
Mark
fireryan
Minnesota
evem with the main breaker shut off? You may be also talking about a fault from the load side of the meter to the main of the panel
fireryan
Minnesota
Mark
I see where your coming from. I wasnt thinking about a fault in the actual service conductors
If there is any fire and/or the Main breaker does not open, call the fire department, call the fire department....did I mention to call the fire department.
It becomes their responsibility. While doing so, try to evacuate the house/building without putting yourself or anyone at too much risk.
