It is a junction box comes with a potlight, however it doesn't come with any clamp or 1/2"KOIs that a fixture junction box, who makes that fixture?
That's the problem, this junction box does not come with any 1/2KO, only the small hole like normal outlet box, however, without any clamp insideI suspect those would only be a part of a listed assembly and not available as an individual item.
Not the wire nuts...... the connection that holds the BX cable to the box.
Sent from MyOuthouse using Toilet Paper
Only the small hole like a outlet box however inside no clamps, if the wire just insert in, it loose and easy to be scrath edA junction box with no way to bring a wiring method into it?
That flex is smaller than MC. Can you show us the entire J-box?It is a junction box comes with a potlight, however it doesn't come with any clamp or 1/2"KO
I will show u when i back to the site, i am at home right now,That flex is smaller than MC. Can you show us the entire J-box?
