Re: Whats wrong with this?
Russ is close, look at the start button when you push it, it energizes M which is the starter coil which starts the motor.
The second post was right thats right the TC can't start timing out because it never sees power.
I don't know what kind of delay this is pneumatic or solid state. Either way the NO TC contact is in series with TC coil.
The TC coil can't be energized this way because of NO TC.The motor would continue to run with the resistors in the rotor circuit it would never pick up to full speed.
The only other answer is it is a simplified diagram and not showing all the controls but I don't think so because it doesn't mention that and it doesn't show any wire conn. take offs for other controls.
Ronald
[ September 01, 2003, 08:33 PM: Message edited by: ronaldrc ]
