readydave8
re member
- Clarkesville, Georgia
- electrician
I usually don't show itemized materials nowadays, but use bigbox cut prices as guideline for what I should be charging
It costs a lot to drive that roll of 10 awg anything when you only need a few feet here and there.I usually don't show itemized materials nowadays, but use bigbox cut prices as guideline for what I should be charging
That's when you ask them if they would go to a steakhouse but bring their own steak and ask if they will cook it for them?Usually won't buy bulk roll on anything above #12 NM, just won't go through a large enough amount on any single job of the larger sizes.
My question would be does anyone compare big box prices to supply house when charging customers?
Usually my supply house gives me a better price than big box. And customers baulk about a price markup much above the price at big box, but I can usually markup to the smallest quantity per unit price from big box to get my markup.
Big box will charge way more per unit for a 25ft roll than for a 250ft roll. Interesting thing I've seen at big box is that they charge more for the 1000ft than for a 250ft roll NM per unit.
I haven't done much for recent comparisons but in past had found that big box is usually only going to have much chance of having a better price on 12-2 and 14-2 AWG NM maybe 14-3 but only in the 250 and 1000 foot quantities. Is the only items they sell in high enough volume to be able to be very competitive on price is my guess. One day supply house may cost less next day big box may cost less but are usually pretty close to one another.Big blue current pricing per ft for 12/2 NM-B at my local.
1000ft $.428/ft
250ft $.432/ft
100ft $.80/ft
50ft $1.28/ft
15ft $2.73/ft
my supply house
1000ft $.401/ft
Go to hardware section and buy a package of maybe 5 screws for a lot more per piece than they would be if you purchased a package of 100. But you maybe purchase it anyway if you don't anticipate needing those particular screws in the near future. If it is something you do use often is kind of no brainer to get the 100 pack. Most big box you can't even purchase a single screw unless maybe it is a rather large one. They will be packaged in quantities of 2, 3, maybe 5. They need a package with a bar code on it for the cashier to have something to scan. Local hardware store here does have pretty wide selection of fasteners, most can be individually purchased but at a pretty high price per piece compared to full packages of usually at least 50 or 100 for smaller items anyway. They kind of go by the honor system and you tell the cashier price per item so there likely is some that cheat at times. I usually give them the right figure though. If I been looking around at other items I may forget, then I just give them a number that I either think is correct or is at least fair based on what prices tend to be there not going to hold up a line of customers or myself for a price check on a 10 -20 cent item.Glad that I'm retired after seeing to what appears to still be high price. Never purchase anything under 250' for #14 to #10 but charging $41 for 15' of 12/2 is a crime. Sure all the big box stores that sell cuts under 250' are cut & wrapped by a fairly fast machine. My brother in law worked at a large refrigeration supply house that had over a dozen branches. They hired a person to just bag & tag hardware & small fittings. Told me they made a fortune selling small overpriced items.
I always hated paying thru the nose for say 5 screws when for a few $ more purchase a box of 100. I must have 40 containers in my garage that each came with 100 screws that I purchased 40 years ago. Lucky to have one great local hardware store that maintained a large hardware inventory. I always went there first if I needed a few stainless steel cap screws & nuts. Glad that I have quality made in USA hardware in stock. Had a lot of bad threads & extra thin flat washers that were made in cheating china.Go to hardware section and buy a package of maybe 5 screws for a lot more per piece than they would be if you purchased a package of 100. But you maybe purchase it anyway if you don't anticipate needing those particular screws in the near future. If it is something you do use often is kind of no brainer to get the 100 pack. Most big box you can't even purchase a single screw unless maybe it is a rather large one. They will be packaged in quantities of 2, 3, maybe 5. They need a package with a bar code on it for the cashier to have something to scan. Local hardware store here does have pretty wide selection of fasteners, most can be individually purchased but at a pretty high price per piece compared to full packages of usually at least 50 or 100 for smaller items anyway. They kind of go by the honor system and you tell the cashier price per item so there likely is some that cheat at times. I usually give them the right figure though. If I been looking around at other items I may forget, then I just give them a number that I either think is correct or is at least fair based on what prices tend to be there not going to hold up a line of customers or myself for a price check on a 10 -20 cent item.
