When exactly to pull Permits??
Jim W in Tampa said:
Not saying permits are a bad idea but look at the real cost.First you as an EC need to fill out the papers and pick up the permit.The real cost is not the $35 fee it is 35 plus your hourly rate.This easily is $100 or more.Now look at customers side of this.Permit made job cost more to start with.Now add in a day of lost work to let inspector in.If it fails for any reason it is now one more day for electrician and another for reinspect.It also raises taxes and that over many years can add up.Also at risk is any other unpermited work they did in past even if not electrical.And in many cases the inspector will barely even look.I have had some for minor remodels not even get out of there car.
OK go ahead and fire back
I will be glad to fire back. First I wish the inspector was paid that much money for his time.
Next I find that some get the job done in a hurry and get paid and get out kind of electricians ,will do some really poor work knowing that it will not be inspected.
Also there is no reason for the inspection to fail on the small job,and if it does then the installer should pay the panalty.
If you are doing work in the towns I work at you can be sure I will give it a good look. I have inspected receptacle replacements that failed because a 3 wire receptacle replaced a 2 wire one without a ground present. I really think the installer didn't think I would check.
Finally There is no such thing as monetary hardship when it comes to public safety.The home owner should be glad to pay the added expense of a permit fee ,to be sure that the person that he paid to do the work is as dedicated to doing code compliant work as those in this forum.
The truth is inspectors see work done by electricians that don't seem to have a clue or a care about the work they are doing. I as an inspector get great satisfaction by stopping them, in the interest of protecting the consumer. I also get a lot of pleasure from working with and doing all i can to help the good guys to get the job done in a smooth and profitable fashion.
Enough said.
