When using the General Method to size the service of a single family dwelling, it is a requirement to increase the largest motor by 25 percent. The question is, which is the largest motor? For example:
A 1 hp motor at 230 volts has a FLC of 8.0 amps and a VA of 1840
A 1/2 hp motor at 115 volts has a FLC of 9.8 amps and a VA of 1127
Section 430.17 requires the FLC to be used in determining the largest or smallest rated motor, but I don't think it applies to Part III of Article 220.
It is a common practice to do service calculations using VA. It seems to me that the motor with largest VA should be inserted into the calculation.
Any input would be appreciated
Brian Dolan
Brian Dolan
