bphgravity
- Florida
Over six months ago, my community was directly hit by Hurricane Charley. For the first few weeks, many installations were made as a "temporary" or "emergency" fix until permanent repairs could be made. In many cases, normal permitting and inspection processes were either intentionally avoided or exempt by permission of the building official.
To date, nearly 100 cases of unlicensed activities are being charged against individuals and companies that came into the area and performed work without permits or required licenses. 27 reported cases of home fires were started as a result of improperly wired generators. 2 reported cases of fire to temporary commercial trailers as a result of improper wiring.
During my daily travels, I have come across dozens of non-compliant and dangerous "temporary" installations to fixed structures, trailers, and other misc. objects, like light poles. I brought this issue up and provided examples at my local IAEI meeting recently and most jurisdictions stated that it is really out of the scope of the building department's jurisdiction to inspect jobs not permitted or installed for the duration of damage repairs to a structure or building.
So, I brought the issue up to the code compliance department and they pretty much said that there wasn't much they could do either. They basically stated that if a building has wiring problems that could create a hazard, then Florida Power and Light shouldn't have hooked them back up and its up to them to make these decisions.
So, I called FPL and they said its not their responsibility to determine if a structure is completely safe for electrical service, that's the job of the building department.
So, its 6 months later and the "temporary" instalations are for practical purposes permanent. I'm suprised there isn't a greater concern. Some of these issues will stay as long as no one tells the owner they must change it, however, none of the organizations that are in charge of that say they can do anything.
Who should be responsible for this? What is the role of code compliance if not this?
I will try to download some pics of some of the more scary installations. In one case, individual cables run across a side walk and connect to a business trailer with open connections right on the ground. While I was taking a picture two kids came by with push-scotters and "jumped" the cables. I have a picture of an RV that is receiving power from a set of jumper cables clamped on the feed-thru lugs on the main panelboard. The deadfront and cover are nowhere to be found. The other end of the jumper cables are clamped onto the RV attachment plug pins and wrapped with duct tape. Yes, no EGC at all.
Its a real nightmare. I could keep Joe Tedesco busy for a month.
