bellington
- Hahira, GA
- Consultant
Can someone tell me what this material is? It is 10mm thick, and 60mm wide. It is the ground bus bar on a switch gear. I assume it is copper with some coating. I need a piece to bridge a gap we had to create between cabinets. It needs to be 20-3/4" long, with a hole on each end with 18-1/4" center to center. Bolt holes need to be 11mm elongated to 13mm lengthwise. Does anyone know of a supplier for metric bus ground bar?
