I think I know the answer. First let me say, if my info is correct, then what applied 100 or so years ago does not apply today as you should ascertain.
For a long time I have searched for the answer; ?Where did the NEC 25-ohm requirement come from?? I always suspected it had something to do with using earth as a conductor, but was not sure. Well after talking to a couple of very old ?FARTS? who can?t remember what your name is, but can tell you what they did in WWI, all had about the same answer, that I think is true. I think read somewhere Mike Holt came to the same conclusion, so maybe he might see this and concur or re-direct.
Back in the 1800?s when Edison built the first distribution system, he used earth as the return conductor which we now call the grounded circuit conductor (neutral for you laymen) 25-ohm happened to be about the same impedance of the phase conductor of a #8 AWG ran 7 miles. The 25-ohm requirement seems to be the highest acceptable impedance that would guarantee Edison?s system to work.
Edison did note that electrical workers did receive a shock from employees working along the distribution path (duh). What I do not know is when exactly distribution systems started employing a grounded circuit in the distribution system that we currently use today. What I do know is the NEC requirement did not follow technology.
This seems to make perfect since too me. In the late 1800?s and early 1900?s when the 25-ohm requirement was added to the NEC (1918 cycle I believe), house hold loads were very low compared to today?s home loads. With a distribution voltage of say several kilo-volts, all one would need is a simple transformer and a ground rod or two on the secondary to complete a sufficient circuit for a household voltage up to several kilo-watts.
To further add credibility is the modern SWER systems employed in Australia and Alaska today. They use the same exact concept of using earth as the return conductor with a 5-ohm requirement
Now of course in today?s distribution system, earth has no or little part, so the 25-ohm requirement is irrelevant and plays no effect in the operation of a household system.
In fact if were to go to the other extreme, and for example we could obtain say something less than 1-ohm, then we would have big problems with voltage gradients or step voltages. If you could even possible obtain such radical values using current distribution technology. Most of the load current from your transformer would flow through earth rather than the grounded circuit conductor. That would cause extreme EMF problems in addition to voltage gradients. Well stop there.
THOUGHTS?
THOUGHTS?
