Re: Where do we use the 1.73 when calculating 3 phase
Thought I would rattle off again.
Ed and Rattus I was taught and thought I learned Threepase 30 some odd years ago.
Rattus I understand you have a very good working knowledge of the field although you
seem to have specialize in electronics that is a plus.
I still believe its like Ed said and I have said all alone, throwing complex math terms
out in the blue is not going to help anybody.
First you need to understand the basic mechanics of how a alternator works.
Then you have to know that a Threepase alternator is really 3 generators in one.
And just telling someone without that basic knowledge that B phase is 120 electrical
degrees behind A phase want work.
After they understand the mechanics envolved with the alternator. The main emphasis
needs to be put on the timing. They need to be aware that just only one phase has a peak
RMS at any one time. If the positive pole or north pole of the alternator field is pointing
dead center with the A phase armature A phase is at its peak RMS or its highest voltage.
The north pole of the armature will not be inducing a voltage into phase B until the
armature has turned a 1/4 of another turn which is another 30 degrees later. First 1/4 of
the cycle A phase is peaked out and before A phase has gone all the way to zero 30
degrees later the north pole field starts inducing a voltage into B phase. Then the same
thing on to C phase.
First glance at a 3 phase delta diagram you first hunch is that one heater is on A phase
and another heater is on B phase and we are using the one conductor to feed both so logic
without a lot of thought tells you the heaters are in parallel so they will pull twice the
current of one heater. But do not forget that when the A phase generating a voltage for
the heater on the A phase that is from line #1 to line #2 that there is no voltage being
generated into B phase which is from line #2 to line #3.
This is really not that complicated, but you do have to apply your mind and once you
grasp this you will figure where the constant multiplier or 1.73 comes in.And you do
have to be using the third leg or all three phases before we use it.
Ronald
