electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
Why would that be required? With a proper splice (no double lugging unless the lug is so listed), what's wrong with feeding two busbars with the same phase? Obviously you'd have to avoid inadvertently sharing a neutral between two circuits that are not an MWBC because they are on the same phase [edit: and you'd need to pay attention to proper OCPD on the feeder conductor feeding two busbars]. Otherwise, I don't see any issue, it would be similar to using a standard 120/240V panel for a 120V only distribution.
Cheers, Wayne
I agree there is no explicit violation. One could argue manufacturers instructions.
