Not correct, sir.you can't have v without I given there is a load
The I is a RESULT of the applied voltage. The voltage is instantaneous. If you look at the Steinmetz equivalent you will see that the voltage is applied to X1 and R1. This means that I is initially zero and builds up as a transient. So, yes you do have voltage without current.
