MarkyMarkNC
- Raleigh NC
If you have a Fluke meter, there is often a guy at trade shows or supplier open houses from Fluke that will calibrate your meter for free.
How do you find them?
As in, send it in to Fluke?
How much does this cost?
The difference in readings may be that one meter is a true RMS meter while the other is not.
You get what you pay for, the calibrations needs to be doen using calibrated instruments traceable to the National Institute of Science and Technology (NIST), you need the proper documentation for this to meet any requirement for you meter cal program.
But if you just want to know if your meter is working right I suppose that would be an option. He is just comparing it to a meter he has there. Think he might say your meter is not accurate and you should buy a new Fluke?
How? Where? I've never had a meter calibrated. Inquiring minds want to know!![]()
a few years back i sent in a fluke to be calibrated. I had to send it to Washington state and it cost me somewhere around $70 total.How do you find them?
Given the high input resistance of these meters it is not likely that a poor connection would change the reading. The only way resistance changes the voltage is the result of the voltage drop that is created by the current flow through the resistance. The current draw of these meters is much too low to cause a voltage drop that is measurable with these meters.They may both be right. There may be a less than perfect connection with one of the meter leads ( resistance caused by arcing or corrosion ).
Hmmm...It probably wasn't an ISO 9001 calibration, but I'm pretty sure they were promoting it as an official calibration. I don't remember what all they did, but it was a lot more involved than comparing to another meter. They took down each meters serial number, and entered them online when they were done.
Whats the "APO" on the Ideal meter display indicate?
I see TRMS on the Greenlee
Great, neither do I.I dont have any of those Radio Shack meters.
1. check the prods as they are positioned in the receptacle swipe(s). Is one receptacle tighter than the other, etc...
2. check the leads of the different testers.
3. You have mentioned the testers are a little older, one used less than the other. Where are these meters stored?
4. have you tested the same testers to another load?
A very good thread and interesting to see if the result of the readings is found.
If you are saying by your answer to #4, that this is common for the meters at other locations, I would say one of if not both meters are not functioning properly.
Like you mentioned earlier, that you usually do not have meters very long, maybe it is time for a new meter...or two.
chris:
Try as many meters as you have on a simple DC source and compare their readings. If DC seems good, then do the same on AC.
