hardworkingstiff
- Wilmington, NC
I want to join a 4/0 code wire to a 4/0 weld wire. T&B suggested using a butt slice (300kcmil code wire rated) with a dieless crimper they make.
I'm considering using a compression lug (T&B 5000 series) properly rated for each wire/cable with a 3/8" hole and bolting the two lugs together. T&B rep said the locomotive industry does it all the time.
I'm soliciting input on which method you think is better and why.
Thanks,
Thanks,
