which Year NEC to Buy
2014 / 2011?
the State where I will Test,
is changing to NEC 2014 in Sept,
I want to take the Electricians test in May.
Has anyone tried taking an Electricians Test,
using a Newer year NEC?
Pro's ?
Con's ?
You can't say that, you have no clue.If you're taking the test is May and you do not have the 2011 NEC already, you will not be prepared to pass the exam, buy the 2014 and take the test after September , by that time at least you'll be able to get around the book.
I studied for less than a month and passed the NJ contractor exam and I could barely figure out how to tie my shoes.
Yes, you can, and you usually do, in fact, give out bad information.Yes I can
EarlT500, Your best best is to get the 2011 and use it to study for and take the test. I have no doubt that you will do just fine if you study hard.
Smart $'s deal sounds good, I would jump on it.
