xguard
- Baton Rouge, LA
We had a control panel installed. It's UL 508 Listed by a control panel shop. I asked a question about a white wire being landed on the equipment grounding bus. It wasn't obvious to me what it was for initially. They said it's for a surge arrestor that was kind of hidden. There's also a black wire landed that should probably be taped green.
The arrestor is a LA 303 by Delta. I don't have the wiring diagram but found this on the website. (I should note this arrestor is not being used in service equipment.)
This is the response I received from the panel shop via the contractor “Yes, the white wire acts as a ground because if there is a surge, it shunts to ground relieving the surge. That does not violate NEC, as the panels are inspected for wiring codes before shipment.”
Am I crazy or is this wrong? It looks like they landed it on the grounding bus because there weren't enough spots on the neutral bus. Thoughts? Not trying to be nit picky with them just jumped out at me. Thanks.
