white wire reidentified as traveler (yes or no)
Re: white wire reidentified as traveler (yes or no)
keenalu1 said:
this debate is worth a lunch to me, as for i have wagered amongst my potential peers.
:D
I'm impressed that you are willing to risk going hungry for a debate over an idea in the NEC. Sounds like you've bit onto being an electrician, hook, line and sinker.
There is no point of Code so insignificant as to escape excessive and exuberant debate by electricians.
Re: fopa
Re: fopa
keenalu1 said:
i spelled faux pas I 've read most of your posts and others who aren't grammatically correct for the most part. i hadn't realized i am amongst such ...( i have no idea how to spell) roadscholars
:wink: :wink: :wink:
If it is Rhodes Scholars, you are looking for; I doubt that we have more than 2 or 3 on this forum. A lot of us are just electricians with no more than a high school education, along with our training in the trade.
If we have any Rhodes Scholars on the forum, I would like to know. Most of the college educated people do not make any more of an impression on me than anyone else. A Rhodes Scholar....now that is another story. I will be very impressed! :) :D :D
Re: fopa
Re: fopa
I spent quite a bit of time learning, out on the roads as a "traveler" electrician. Does that qualify me as a roads scholar???
Michael, If you had left out the 1 to 2 percent of your posts that I have not agreed with, I would say absolutely. But; alas that one or two percent. :p :p
Re: i.e. ( for instance) cold switch ( what is for a 1000?)
keenalu1 said:
a cold switch- in lay persons terms- is when power or hot or ungrounded single or three phase conductors ...providing it's less than 300 volts between system phases in the same box, enclosure,etc(etcetera) ...in an unsupervised,or otherwise unattended SINGLE FAMILY DWELLING....... (oh?!.. where was i) is brought to the light, receptacle, or whatever and thus (utilization equiptment)..... ( ...."()"- means a thought amidst meanstream thought....although the code inerprets a receptacle as a device and therefore could potentially be an exception to the topic at hand...) two wires ...( well really three because we need to ground said switch...)are extended beyond the light to a single pole single throw switch for arguement sake... which is not the case in my question ... were this box is the only means of disconnection for said utilization equiptment ... ( once again the light?!@#!)
eschew obfuscation
. . . seriously - if you would simple write a straight-forward sentence I might be able to understand what you are trying to say. A stream-of-consciousness recital of what seem to be random synaptic misfires is difficult to comprehend.
BTW...It's RHODES" Scholar
Maybe if you live in Australia, but according to the American Association of Rhodes Scholars. It is Rhodes Scholar.
keenalu1,
George gave you an excellent thread to link to and read in his post at the bottom of page one of this thread.
Also, you'll find more fuel for your lunch debate at this thread: Using neutral as a traveller on 3way switch
Depending which side you've chosen you may find the following interesting, that is, the fact that the branch circuit breaker (15 or 20 Amp 125 Volt) is very likely to be listed as a switch, making the branch circuit home run a "switched leg" before it even reaches a "light switch".
Edit - Redirected URL to new Forum location
Al
Al,
I have a question i try to hit the link seems dont work with me today i dont understand why but if you willing try to fix this link ??
{ i can understand this format did change so kinda like chase bug again }
this above that is your qouteation so
thanks for your time to review this
Merci , Marc
Why do we need to reidentify the white conductor anyways, isn't it obvious as to what is doing when you see it connected to any switch?
Heretic! :D
With the advent of the AFCI breaker, I imagine it becomes a bit cloudier as time goes on. We must protect the innocent from themselves at all costs. :roll:
bad asses do exist
bad asses do exist
the code only states three colors. white [for neutral only], green [for ground only], and orange [for stinger leg of 240 delta system]. no exceptions...
Not true Billy, read 400.22, 424.35, 504.80, and 517.160. You are right in that there are no exceptions because these are not exceptions.;)
Roger
roger said:
Why do we need to re-identify the white conductor anyways, isn't it obvious as to what is doing when you see it connected to any switch?
The only reason that we re-identify the white conductor that's on a switch, is, 'cause we a supposed to.
'Em electrons don't care what color the insulation is!
The average "trained" electrician knows why it's there (that its being used as a switch leg/traveler - and not a neutral) but, we have to be considerate about the next schmuck that stumbles into the circuity.
No - we can't make it idiot proof. As idiots are getting dumber all the time.
We just have to make a good faith attempt, to let somebody else know, "whazzup".
