al hildenbrand
- Minnesota
- Electrical Contractor, Electrical Consultant, Electrical Engineer
Re: White wires as travelers on 3-way
Take a look at 800.2. The NEC uses "factory assembly" to define one or more conductors as wire. It also uses "factory assembly" to describe putting a cover over one or more conductors and defines cable.
Now, the 800.2 factory assembly of wire, used to assemble a factory assembly of cable is what is defined in 800.2. The use of the word "subassembly" would lead to a hall of mirrors, linguisticly. . .as it is in this thread. . . The point is, an assembly can be assembled from an assembly.
Nor am I contending that NM is a factory subassembly. I absolutely agree that NM is a factory assembly. Its just not, by 334.2 a cable assembly. . .the modifier "cable" is not there.it still is not a factory subassembly.
