- Massachusetts
The following based on the 2002 NEC
The FMC outside
348.12(1) specifically allows FMC to be installed in wet locations with some provisions.
So IMO the installation may have met the code at the time.
The sizing
702.5 requires the generator to be sized to power all the load intended to be operated at one time.
It also goes on to say that 'the user shall be permitted to select the load connected to the system.
IMO this means the installation you describe met the code at the time.
The fact the NEC change the requirements for the 2008 proves this to be true as now it is clear when using an ATS the generator must be capable of supplying all the load on the ATS. (Not including any shunted loads as Larry suggested :smile
The FMC outside
The sizing
