I_am_Im_Me
- Wisconsin
I may be reading this wrong but it seems to me your foreman took issue with you using the fixture wire to connect to the 12s coming in to the 12s leaving the fixture and continuing the lighting branch circuit to feed the last two fixtures. As I read your post I had the impression you did not splice the 12s together you came in one end taped to the fixture wire then tap the fixture wire at the other end and continued that to the next fixture . Please clarify if the 12s in the fixture where spliced together or you used the fixture wire to connect the 12s together.
"Those 12's in the flex(feeders), along with the 12/2's from the 6 foot mc factory fixture whip in that last j-box on the crowded side of the corridor will both splice into the #14 fixture taps in this particular fixture "
I'll see if I can clarify.
Had I done it my way, I would have come in one side of the fixture with the whip containing the 12's. I then would have come out the other side of the fixture with 12's in order to continue my lighting branch circuit feed to hit the last two fixtures. Had I done that, I simply would have pigtailed the 12's and stabbed the pigtails into the disconnects on the fixture leads.
I would not have done any splicing involving the fixture wires.
Hope that helps to answer your question and clear things up a bit. I'm new here and I guess I'm not all that good at explaining myself judging by all the confusion.
Will try and do better on any future posts.
