Why 112kVa?
Maybe it is USA. I have not seen the 1.125" else where and I have travelled extensively. C'est la vie.
This is what is very common less the fractional identifiers.
Occasionally you even find 1/32 division marks. Most of us tradesmen don't need to be any more accurate than 1/16 of an inch or in cases where we do we are using something more precise to take the measurement like maybe a caliper type tool. The tape has a mark at the 1.125 distance though it is not specifically identified as the 1.125 mark.
I do have a 100 foot fiberglass tape measure that is only marked in 1/4" increments. I suppose they figure if you are using that long of measuring tool accuracy beyond 1/4" tolerance is not normally important. A lot of the time I am rounding to next foot or even five feet interval when using that tape.
Yes, that would explain it. We use metric for industrial excusively. Metric or, more accurately, SI - System International. Many older people still use feet and inches but I dropped it when I travelled extensively.
Yes, I accept that it is routinely used for USA measurements - just not elsewhere in the world. Unless you want pint in the pub.............................:)
No, that's the footage plus the red number; in this pic, it's 1'7.2", or 19.2".
It's 1/5 of 96" which can be used to space studs wider than 16" O/C.
My father was a farmer. I have a notion that he used some of such measurements. I was already comfortably set in my ways with metric units. My wife, from GA, is now pretty fluent particularly with domestic things.
I think another application where this increment is used is for wall paper, I think it comes in 19.2" wide rolls.
