kwired
Electron manager
- NE Nebraska
- EC
Many POCO's safety practices sort of eliminate those from happening.Anyways, can you give me a scenario regarding 480 volt arc flash and linemen?
They usually kill the transformer before doing any work on secondary, or if a self contained meter they may require a line side disconnect to be opened before working in the meter socket. Beyond those activities that they don't encounter 480 volts as often as 250 and below.
250 and below they will have a transformer supplying multiple customers quite often and if they can won't interrupt one while working on something that supplies another customer.
480 volt services is often supplying one service. If you are going to have to do a task that interrupts any conductor chances are you at least want to turn off the main regardless. If only supplying one customer then if you are killing their main, why not kill the entire secondary before working on it? reduces the risk of injury.
