h
Aren't even (ex. 4) phase motors have two opposing magnetic force thus producing a more difficult mechanical element to balance?
Not necessarily, because a single phase will generally show up at different locations on the stator, and can easily be connected to provide 'inverse' slot current flow. Thus with any number of phases you can connect the machine for balanced magnetic forces.
Consider a conventional three phase 2 pole machine. You have a total of _6_ phase bands in such a machine: A (0?) C' (60?) B (120?) A' (180?) C (240?) B' (300?) and back to A. The primed phase bands are simply the normal electrical phases, but the direction of the wire in the slots is in the opposite direction, so the effective slot current produced by current flow in these wires is 180? out of phase with the corresponding non-prime phase band.
It is this symmetry that ends up being a problem for certain systems, eg. 4 phases. Because your A phase also provides your A' phase simply be reversing the direction of the wires, it is a waste to externally supply phases that are 180? apart. So a 4 phase motor will be supplied with phases that are some multiple of 45? apart. However there is no arrangement of four 45? multiples that will evenly divide 360 degrees, so you cannot use the 4 phase analog to a wye connected motor; either you are forced to provide a neutral wire or you are forced to use 8 wires. If you provided the neutral, then you could drive such a motor, and have balanced magnetic pulls...but geting a neutral out of a VFD is a pain because you either need to synthesize it or you need to generate your DC with a neutral.
If you want to build a 6 phase machine, you could supply 0, 60, 120, 180, 240, and 300 degree phases, but you have the same issue with inversion; such a '6 phase' machine is simply a different way of powering a conventional 3 phase machine. Another approach is to build a machine supplied with 0, 30, 120, 150, 240, 270 degree phases; essentially you have two balanced 3 phase sets, offset by 30 degees from each other.
-Jon
