220, 240, whatever it takes.
Using 240v with an insulator that's rated 250v just gives you a feeling of safety factor.
Or look at it another way, the 250v rated insulator is probably good for 9+kV in std temp/pressure/atm, but running 250v on a rated 250v item just sounds like living on the edge. 10v(rms) is a good safety margin.![]()
Most equipment is tested at a minimum to 200% of nominal plus 1 kV so a 250 V plug should survive 1500 V. A lot of distribution or service entrance though gets much higher (BIL) ratings.
