- Windsor, CO NEC: 2017
- Hospital Master Electrician
Julie, not to gang up on you, but given that this is a new house still under 1-year warranty, I'd bet $15 that the kitchen lights are not on the same circuit as the fridge.
Given the abundance of colored romex, it would be a profound error on both the installer and the inspector not to catch such an obvious violation, IMO. White romex running into a fridge receptacle should arouse some curiousity, and it wouldn't be terribly difficult to confirm visually at rough if it was a dedicated home run.
I'd say it's probably just normal voltage drop and a touchy customer. I had several of these, and never put a fridge on the same circuit as the lighting. Usually, it was "my lights dim for a second when the A/C kicks on" and none of the circuits were loaded close to their ampacity.
Drop happens.
Drop happens.
