GreenAcres
- Chicago
- Retired Contractor
I'm not planning on doing this, but I don't understand why the code doesn't allow mixing wires with different insulation ratings in the same conduit. For example I work with THHN which is 600v and PV wire which is 1K/2K rated. Each of them has insulation that is adequate to allow the wire from shorting out to to the metal conduit. So why isn't the insulation on 1K wire adequate to keep it from shorting out on the insulation of 600v wire? Or is there some other reason they can't be mixed? I would think the concern would be more about thermal ratings rather than voltage ratings.
