Let's not get sideways. Fault current, of any type, is not what magnetizes conductors when a motor starts.
I was talking about my laser printer noise.
Consider two parallel wires separated by a distance R that are flowing equal currents I in opposite directions. The magnetic fields that encircle each of these two wires will therefore circulate around their respective wire in opposite directions (i.e, they'll have opposite polarity). And so as you move away from the pair of wires, their magnetic fields will cancel each other as others have noted. But in the space between the two wires the circulating magnetic fields will be going in the same direction and actually add to each other, not subtract. Think of it like two gears that are meshing and rotating in opposite directions, but right where the gears make contact they are moving in the same direction. Because the magnetic fields created by the wires have the same polarity there will be a repulsive force between them. The strength of that force will be proportional to I2/R by Ampere's force law. And so the repulsion force will go up quickly as the current is increased.
Now I think the rattling is caused when the force is: 1.) sufficiently large to overcome friction, gravity, wire stiffness, etc. that will otherwise keep it in place, 2.) the duration of the force is long enough and it's sufficiently strong to accelerate the wire and move it a large enough distance to cause a rattle, and 3.) the duration of the force is limited, because otherwise the wires will likely just move to another place and stay there (i.e., another equilibrium point) instead of jumping and returning back which I think would be more likely to cause a rattle. A constant application of 60Hz current will create a repetitive force that peaks every 1/2 cycle of 60Hz, but the inertia of the wires should prevent that from causing any significant movement over each 1/2 cycle (probably at most a buzzing noise) . So I'd expect 60Hz to have a similar effect as DC. It shoud be noted that the polarity of the AC current changes each 1/2 cycle, but the direction of the resulting force is the same (repulsive) because the currents are still flowing in opposite directions.
By the way, I found the following that shows waveforms of the surge current from the heat lamp of a fuser in a laser printer:
And the laser printer doc is interesting. Digesting it now, ty.This is entirely plausible, respecting the mass of the individual conductors and their resultant resistance to motion.
But as an EE, which I'm a light year away from, am I out of line hypothesizing that when either current or voltage lags or leads the other, it becomes increasingly difficult to achieve the field cancellation effect we strive for by ,for instance, limiting # of conductors in a conduit?
I question whether reactance matters much. In two wire inductive circuit current will still be out of phase with voltage by same factor in both conductors. It is the current that is causing the magnetic field around the conductor(s) regardless of what phase relationship is to the supply voltage, and same for simple ammeter to function as well.This is entirely plausible, respecting the mass of the individual conductors and their resultant resistance to motion.
Not to parse words, but it's the change in current that is causing the magnetic field. My assertion is that in a circuit that's trying to bring a motor from 0 RPM to x RPM, current lags voltage making it more difficult to 'net zero', or cancel out magnetic fields.I question whether reactance matters much. In two wire inductive circuit current will still be out of phase with voltage by same factor in both conductors. It is the current that is causing the magnetic field around the conductor(s) regardless of what phase relationship is to the supply voltage, and same for simple ammeter to function as well.
"Not to parse words" then I parse words.Not to parse words, but it's the change in current that is causing the magnetic field. My assertion is that in a circuit that's trying to bring a motor from 0 RPM to x RPM, current lags voltage making it more difficult to 'net zero', or cancel out magnetic fields.
Many breakers are designed in a manner that uses the magnetic forces from the high current to help separate the contacts for faster clearing.Nope. Contacts don't blow apart in an extreme short circuit. They fuse together. They WELD together.
What an incredible place to learn. Thanks Don.Many breakers are designed in a manner that uses the magnetic forces from the high current to help separate the contacts for faster clearing.
Circuit Breaker Contact Arrangements: Straight-through vs. Blow-apart
The flow of electrical energy in a circuit breaker is controlled by a contact assembly. When a circuit breaker is tripped or manually operated, the circuit breaker interrupts the flow of electrical energy by separating its contacts. As the contacts open a live circuit, current continues to flow...testguy.net
If you weld with DC current at higher settings you can get "arc blow" which bends the arc because of magnetic forces.Yup. Well any of us that weld at all at one time looked at all the pretty metal dust lined up next to the welding cable on the floor.
1) When current flows in a closed circuit, that forces between the individual circuit conductors always tend to push the conductors apart. Doesn't matter if this is DC or AC; if you have current flowing out on one conductor and back on a parallel conductor the net result is that the conductors get pushed apart. This does not require fault current or current flow on conductors external to the normal circuit path; this is just blog standard 'how current works' in a circuit.
-Jon
5) I am imagining an experiment; take a standard 16ga lamp cord, split the conductors apart and stretch them between two supports so that the conductors are about 1/2 inch apart, 6 feet long, and stretched so that their natural resonance is 120 Hz. Run say 1A of 60Hz AC through the cord and I bet it will visibly vibrate.
-Jon
If and only if the two or three conductors were concentric would the field immediately outside the outer conductor shell be zero and would the magnetic forces among the wires net to zero (assuming they are perfectly centered).Negative. If you have current flowing out on one conductor and back on a parallel conductor the net result is Zero. In a perfect world EXACTLY zero, every time. Try it. Clamp your ammeter around a piece of romex and you know the result. If the net current is zero the magnetic field is zero. If the field is zero the copper wires do not become magnetic therefore cannot attract or repel each other or the conduit.
Go back an look at the breaker link I posted. They made the current flow in opposite directions by the physical design of the contacts, to help force the contacts to open.Negative. If you have current flowing out on one conductor and back on a parallel conductor the net result is Zero. In a perfect world EXACTLY zero, every time. Try it. Clamp your ammeter around a piece of romex and you know the result. If the net current is zero the magnetic field is zero. If the field is zero the copper wires do not become magnetic therefore cannot attract or repel each other or the conduit.
